RP91 Copyguard?
Discussion in 'Archived Threads 2001-2004' started by Chris_A_J, Jun 20, 2002.
  1. Chris_A_J
    Chris_A_J Extra
    May 5, 2002
    18
    I just got my new RP91, that I exchanged for my SD5700, hooked up on my Toshiba 50HX81 and I am having a problem.
    I was trying to calibrate my set to the RP91 with Avia and I noticed something strange. On the sharpness adjustment on Avia the top middle line was jumping up and down as was the side lines on the left side of the screen. This was in progressive mode....when I turned progressive off it stopped. Does anyone have this combo or know what could be wrong. I read in the manual that there was some type of copyguard protection on progressive output. Is there a way to get around this? As of right now I AM PISSED!!!!
  2. Chris_A_J
    Chris_A_J Extra
    May 5, 2002
    18
    OK.....I take it no one knows [​IMG]
  3. Rachael B
    Rachael B Producer
    Jun 5, 2000
    4,731
    43
    1,610
    Knocksville, TN
    Rachael Bellomy
    Isn't it possible your RP-91 is defective? I don't have your TV set but I have the RP-91 and it's worked well for me, in progressive. Best wishes!
  4. Chris_A_J
    Chris_A_J Extra
    May 5, 2002
    18
    Yea, I guess that is possible...it was a dealer demo.
    Anyone else have any ideas??
  5. Jeremy Little
    Jeremy Little Supporting Actor
    Jun 9, 2001
    770
    110
    Sounds more like a de-interlacing artifact to me. I don't feel like pulling out avia and trying it on my RP-91, but I believe I know what you are referring to. Your player is nice, but it has only a "good" de-interlacer. There are better ones out there, and that is not the only feature one should buy that player for. Overall, I think the majority of people like it for its overall superb picture, scaling of non-anamorphic discs, format support, and all in one box too. There are going to be a few "glitches" in its de-interlacing, but what can you do.....
  6. StephenMSmith
    StephenMSmith Stunt Coordinator
    Apr 29, 1999
    85
    You just need to set the deinterlacing mode to Auto 2.
