RP82's MPEG Noise Reduction settings??
Discussion in 'Archived Threads 2001-2004' started by Kevin. W, Jan 25, 2003.
  1. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    I was skimming through the manual of my new RP82 and saw a section on MPEG NR. My question is what values do you set them too.
    3D-NR(0 to +4)
    Block NR(0 to +3)
    Mosquito NR(0 to +3)
    I assume if you set all to max yould just end up blurring the image to smooth it out. What has everyone found as the best settings. RPTV is a Panny 47wx52.
    Also are there any firmware updates for the RP82??
    Kevin
  2. Kevin. W
    Oct 27, 1999
    1,534
    Anyone?
    Kevin
  3. Greg Kolinski
    Greg Kolinski Second Unit
    Oct 13, 2002
    331
    I may be totally wrong,but I set all the noise reduction ,sharpness etc to zero,from what I understand it just creates more artifacts.Anyone PLEASE correct if Im wrong
    thanks
    Greg
