rp82 settings
Discussion in 'Archived Threads 2001-2004' started by hwshi, Nov 2, 2002.
  1. hwshi
    hwshi Stunt Coordinator
    Aug 5, 2000
    131
    man i feel sorry for people who can't even set the time on their vcrs!
    ok here goes.these are my settings after what i gathered in numerous searches on the rp82.
    i have an xbr400 and am running it in progressive mode.
    -picture mode-u1/3d nr-0/block nr-0/mosquito nr-0
    -u2/transfer mode-auto1
    -still mode-auto
    -black level-darker
    -digital audio output-on(remaster off) not clear if this has any affect on dvd movies?
    -dynamic range-off
    what i've found with these settings (keeping in mind that i had last callibrated my tv with a sony dvp36 interlaced player) was that i had a VERY dark picture and the reds are way hot.is this normal for this progressive player? i did recallibrate last night and haven't had a chance to check out the results with a movie yet.the blues are dead on, the red is 20%+ and the green is -20% so i had to bring down the color settings to normalize the red.
    i had to push up my brightness and picture to almost 50% to be able to faintly see the the brighter moving black bar on one of the avia tests.thats from it being set at about 30% with my old dvd player.however the sharpness tests rock! were i used to get a little flutter from some of the finer lines,they are rock solid now.sharpness is around 30%
    just wondering if this is normal to have some settings so high after switching from an interlaced player to a progressive player? i found my xbox to also be dark,which was my first chance to see progressive signals on my tv.
    any comments appreciated
  2. Guy Usher
    Guy Usher Supporting Actor
    Oct 20, 2002
    780
    I have noticed the same thing with some DVD players, interlace being much brighter than progressive, however I recently purchased a Tos SD3800, both modes were dead on. Are there known players with this "problem"? My Sony NS700p does this, not drastic but a signifant difference between the two modes. . .
  3. hwshi
    Aug 5, 2000
    131
    hi guy,that's what i am wondering too.however i noticed that my xbox is also dark,so it makes me believe that a progressive signal output is darker,or it's an xbr issue.
