RP: What Should I Avoid?
Discussion in 'Displays' started by Kevin Webb, Jul 17, 2004.
  1. Kevin Webb
    Kevin Webb Agent
    Aug 3, 2001
    44
    Rather than ask what I should get, I am taking a different tack and asking if there are any Rear Projection TV's I should stay away from?
    I am moving into a new condo in a few weeks and I want to pick out my new television and have it ready to go when I move in. I am looking at between a 50-57" model.
    So far, what I have seen out there I have been pretty impressed with. Specifically the Sony 51", Panasonic 53WX54 and the Mits 55613. Every day it seems that I keep changing my mind on what to get.
    I know there was a Sony model that had some serious issues but is there anything else I should avoid like the plague [​IMG]
    Kevin
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Kevin,
    Sony had a flicker problem on HW-40 and WS-500 models from about December of 01 to about a year ago. Current models are fine.
    Of the 3 sets you've listed I don't think you'd go wrong with any of them. I'd avoid unusually cheap-for-the-size models like the $1199 55" Magnavox at CC but in the 51-57" size range just about anything from Sony, Toshiba, Mitsubishi, Hitachi, or Panasonic should be just fine.
  3. RobertC
    RobertC Agent
    May 25, 2004
    32
    Kevin
    I second Hitachi.They are number one right now.
    Hope this help.
    Regards
    RobertC
  4. StephenHa
    StephenHa Second Unit
    Sep 28, 2003
    364
    hitachi makes a great set as does mitsubishi or panasonic
