John-Miles
- Nov 29, 2001
has anyone compared these two? any input on what the differences are. which one would people out there suggest?
What exactly does scaling do?It performs a vertical stretch on non-anamorphic letterboxed DVDs. While this doesn't actually improve the image of these DVDs, it makes the image better match the optimal scan rate of widescreen sets that have shitty 'zoom' modes of non-anamorphic letterboxed material and makes these discs look better on these sets.
At least one person at AVS felt the 82 looks better than the 91.There's at least one person who thinks the RP56 is better than 91 and there's at least one person there that thinks a jvc, sony player etc. is better than the RP91.
Point is that you got to decide for yourself which is better. Most of the time the question is not which is better but which to them is more value. Like anything you probably want the more expensive perhaps higher rated unit but you can't justify the cost so you try to like a cheaper player over the more expensive player. The consensus is that the RP91 is simply better than the 82. It's the same old RP56 vs 91 debate. Decide for yourself. There are something that the RP82 does better and there are some things that the Rp91 does better. Overall I think the RP91 is a better all around unit. Better built better chips etc. whether that's worth the extra money is another question.
