Todd Stout
- Jul 13, 1999
I need to get my hands on a router to use to make the driver and internal brace cut outs for a set of 3 Adire kit281s and 2 kit81s. I probably won't need it for much else besides the speakers so I'd prefer to keep it inexpensive. I first found the 2HP Firestorm Plunge Router at Lowes for $69 but it doesn't seem to be compatible with the Jasper Jig. I started looking at the routers that are listed on Jasper's site and they all cost about $180 on up. I see that Sears has the Craftsman 1/4 in. Plunge Router for $69 but I've read some bad reviews of their cheaper models. I also found the Ryobi RE180PL at Home Depot for $99.
Will a $70-$100 router work well enough to make the holes I need for 5 speakers or do I need to spend $150-$200 to do the job right?
Thanks.
Thanks.
