Rotel Vs. Denon
Discussion in 'Archived Threads 2001-2004' started by Olivier P., Dec 17, 2002.
  1. Olivier P.
    Olivier P. Auditioning
    Dec 13, 2002
    2
    I hope someone can Help me out ...
    My current set consist of B&w CDM7-NT Fronts, B&w DM 600 S3 rear en B&w ASW675 Sub. Currently powered by a Yamaha RX-V620RDS. Now, The Yammie has got to go !!
    It is not musical and way to bright ...
    I have 2 options, I can buy a Denon 3802 for 850 € or I can buy a Rotel RSX-972 for 995 €. In belgium the normal price for those receivers is 1500 € for the denon and 1585 € for the Rotel... I know , it's much cheaper in the VS ...
    Any ideas, I want a warm sounding , detailed and musical solution ...
    I just can't decide...
    Thx
  2. Arnold van Oostrum
    Sep 12, 2002
    33
    Olivier,
    I think the best you can do is listen to both. The Rotel is an older model, that has NO DPL-II, DD-EX and DTS-ES. The Rotel is very musical with a warm and good detailed sound.
    The Denon has more recent surround options that the Rotel lacks. The Denon sounds detailed but a little bright. The Denon sounds a little more dynamic.
    With your wishes (warm, detail and musical) I think the Rotel is your choice.
    The newer Rotel RSX-1055 is very much like the 972, but has all the new surrounds options.
  3. EarleD
    EarleD Supporting Actor
    Aug 27, 2000
    728
    3
    I agree with Arnold about the 1055, its a great receiver. I should know as I have one being used as a preamp.
    I used to have a Denon 3802 and the 1055 blows it away. The sound is much more detailed and focused. The 1055 can drive 4 ohm speakers without any problems, how many receivers can say that?
    I have older Klipsch speakers(kg series) and the Rotel matches up perfect with them. With my 3802 and Acurus amps watching a movie at reference levels was difficult, with the 1055 its easy.
    Earle
  4. Olivier P.
    Dec 13, 2002
    2
    Hmmm ..
    I'am leaning more towards the Rotel RSX-972.
    If I could buy the 1055, There would be no problem ...
    Al the processing options of the 3802 and the amp of the 972...
    Nobody knows where I could get the RSX-1055 cheap ?
    It has to be shipped to Belgium ...
    THx
