Rotel RSX-1055 same as 1066??
Discussion in 'Archived Threads 2001-2004' started by Robert McClanahan, Dec 23, 2002.
  1. Robert McClanahan
    Robert McClanahan Stunt Coordinator
    Jul 21, 2000
    188
    I just bought a Rotel RSX-1055 for just under$1200.00 including tax.I have seen the RSP-1066 processor and can find no difference between the two except the 1055 has five 75watt high current amps.My question is why would Rotel charge so much more for a 1066?The 1055 even has a RDS(radio data system) tuner!!
  2. EarleD
    EarleD Supporting Actor
    Aug 27, 2000
    728
    3
    Thats why I bought my 1055. Great receiver.
  3. DanaA
    DanaA Screenwriter
    Nov 21, 2001
    1,843
    According to Rotel, there are some differences, but, from what I've read, you'd be hard pressed to notice any of these differences sonically. Yes, considering most consider the 1066 a pretty good deal at its price point, you got a magnificent bargain, given the power amp is assignable and the addition of the tuner. Now, you won't have to spend the extra money should you decide to go 7.1. So, given that you bought if for significantly less than most can get the 1066, you got unbelievable equipment for the price. I'll say you did well...[​IMG] [​IMG]
  4. Robert McClanahan
    Jul 21, 2000
    188
    Dana,do you work for Rotel?[​IMG] Just kidding.This is the first receiver in my view that is worthy of later being a seperate pre/pro if I later upgrade the power.I think this unit sounds so much better than the Japanese rigs I have auditioned with all the bells and whistles.[​IMG]
  5. EarleD
    Aug 27, 2000
    728
    3
    Im using it as a preamp with a 1070 and a 985mkII amp. Sounds great.
    Couldnt see spending the extra $$$ for the 1066 when I wouldnt be able to tell the difference.
    Earle
  6. Robert McClanahan
    Jul 21, 2000
    188
    Earle, did you know the processing chip in the 1055 and 1066 is the same one used in the Theta casablanca?[​IMG]
  7. EarleD
    Aug 27, 2000
    728
    3
    I didnt know that. Very Cool[​IMG] Nice to know that your getting the same processing as the high dollar machines.
    With the new firmware ver 1.48 in beta testing, hopefully the BM problems will be fixed. So far Rotel has been great with their customer service.
    Happy Holidays
    Earle
  8. DanaA
    DanaA Screenwriter
    Nov 21, 2001
    1,843
    As for me working for Rotel, you'd think they'd get the hint and hire me for their advertising department, wouldn't you? [​IMG] You're gonna love that receiver. And, not just for home theater. The two channel is superb for a stand alone unit.
    Oh, and one more suggestion. I'm going to link you to a site when they have a dedicated Rotel discussion board. It's the best place to keep updated on new developments with Rotel.
    Here
    Signed,
    Dana,
    Chief Advertising Wannabe,
    Rotel Corp.
  9. Robert McClanahan
    Jul 21, 2000
    188
    Dana,you da man!!!
  10. Rich Wenzel
    Rich Wenzel Supporting Actor
    Aug 9, 2002
    556
    one question about the older rsx-1055's (i have one), is the lower video bandwith fixed with a firmware upgrade (i.e. is it a software problem) or is it hardware fix?
    I was thinking about using the componenet switching on my rsx.
    Rich
  11. EarleD
    Aug 27, 2000
    728
    3
    Rich,
    I'm pretty sure the video bandwidth upgrade is a hardware issue and will need to go back to Rotel to be upgraded.
    Earle
  12. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    Yes we owners' of the older ones will have to send it in for an upgrade.[​IMG]
  13. Wolfgang.K
    Wolfgang.K Agent
    Sep 26, 2002
    28
    Hmmm....interesting. I was considering the 1066. Looks like I should give the RSX-1055 A listen.
    Does anybody have Canadian pricing on these units. What is the best price i can expect to pick it up for? Oh and the
    RMB-1075 if possible would be much appreciated.
    W.K
  14. BrentPollard
    Dec 18, 2001
    445
    I picked up my 1066 +100' of 12g wire and 2 DVD's for 1850.00 $CDN at the end of June here in Saskatoon. So you should be able to get a 1055 for somewhat less. [​IMG]
    P.S Merry X-Ma$
  15. Wolfgang.K
    Wolfgang.K Agent
    Sep 26, 2002
    28
    Thanks Brent!
    That seems quite good [​IMG].
    Thanks again,
    W.K
