Rotel RSX-1055 Owners - A few questions for you.
Discussion in 'Archived Threads 2001-2004' started by Joe, Nov 2, 2002.
  1. Joe
    Joe Stunt Coordinator
    Jul 27, 2002
    139
    A few questions for you on the RSX-1055.
    1 - How do you like the RSX-1055? Any problems with it?
    2 - I see that there has been multiple upgrades for the RSP-1066. Is the RSX-1055 treated the same way?
    3 - Does it have DD-EX?
    4 - How well would this work? I would like to reassign the front L/R channels to power the rear backs and then use my Rotel RB-1080(2x200)amp to power the front L/R. Anyone do this without problems?
    5 - How much does it cost?
    6 - Anything else I should know?
    Thanks so much.
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Only the bass management which is been addressed right now.
    The 1055 and 1066 use the same firmware so when one gets updated so does the other.
    yes
    Many people are doing exactly the same thing
    depends on how much your dealer will come down from list...figure 10 to 20 percent off list ($2000 cdn)
    There's a dedicated Rotel user forum on the HTGuide site
  3. Joe
    Jul 27, 2002
    139
    Andrew -
    Thanks for the information. Any ETA on the Bass Mgt fix?
  4. Joe
    Jul 27, 2002
    139
    Anyone else have an opinion on the 1055?
  5. Gianni
    Gianni Agent
    Oct 21, 2002
    25
    I had a chance to demo the 1055 and compare it to a B&K avr307. Keep in mind that the 307 is over twice the price. I like B&K and was sure the 307 would have a leg up on the 1055.
    In a nutshell, the differences were much more subtle than I expected. Granted, they were using different sources for CD, but they were of similar quality. In this setup, the 307 actually came off as a bit brighter. In all other areas,the two were remarkably close. I think you would probably start to see the differences in the two with more demanding speakers or at higher output levels.
    All in all, the 1055 did very well--quite well for the price point.
  6. EarleD
    EarleD Supporting Actor
    Aug 27, 2000
    728
    3
    The 1055 is a great receiver. Match it up with a 2 channel amp and you have the making for a sweet HT/music setup. The 1055 blows my Denon 3802 away both in HT and music. Seems to be more focused and detailed. I have been noticing new things on both cd and dvd.
    Im sure that Rotel will take care of the BM issues with the next software upgrade.
    Ask away.
    Earle
    PS. Got my 1055 for $1170+tax
  7. Joe
    Jul 27, 2002
    139
    Earle -
    I am considering using my 2 channel amp for powering the front speakers but I read somewhere that choosing to redirect the power from the front L/R speakers to the back rear speakers did not work right (a 1055 bug). Are you setup this way and if so do you run into any problems?
    Thanks.
  8. Arnold van Oostrum
    Sep 12, 2002
    33
    Those re-direct problems are cured with new firmware. Problem was that the re-direct info was lost after powering down the unit and had to re-entered everytime the was switched on. That's cured now.
  9. EarleD
    Aug 27, 2000
    728
    3
    Joe,
    Im using a Rotel 985mkII 5 channel amp and having the receiver power the center backs. Arnolds right about the firmware fix, have had no problems once I upgraded to version 1.47
    Earle
  10. Joe
    Jul 27, 2002
    139
    Thanks for the 1055 info. I'm really torn between the following 3 options.
    In each option I would use my existing Rotel RB1080 2ch amp to power my front Paradigm 60s. Rear center speakers are some older Boston Acoustics. Paradigm center as well.
    1 - $1200 - Buy the 1055 and Paradigm mini monitors for the rear sides.
    2 - $1300 - Buy the Marantz 8200 and Paradigm mini monitors.
    3 - $2500 - Sell the kids and buy the Rotel 1066 pre/pro, RMB 1075 5 ch amp and Paradigm mini monitors.
    Option - for another $300, I could replace the mini monitors with the Studio 20s. Do you think 20s are a waste?
    If money and space were not a problem, #3 would be my choice. Unfortunetly, I'm tight on both but could still possibly pull it off. I just don't need to spend the extra grand for a slightly noticable sound improvement.
    Any comments????
  11. EarleD
    Aug 27, 2000
    728
    3
    Have you listened to the Marantz? Listen to both and get the one that you like.
  12. Andrew Pratt
    Dec 8, 1998
    3,806
    I'd go for the Rotel 1055 with the upgrade to the studio 20's...they're a much better sounding speaker then the mini's.
  13. Rich Wenzel
    Rich Wenzel Supporting Actor
    Aug 9, 2002
    556
    one thing that is nice about the 1055, kind of a hidden bonus, is that everytime rotel updates its highest end hometheater product (1066), you get that update on your receiver...doesn't sound like much, but audio companies tend to update their higher end stuff more often...
    one annoying thing, and it may go away with newer firmwares (just havent had the time to do look into it) is that if you have dpl2 or dts neo6 on, you can hear little clicks when you change the volume of the unit.
    rich
  14. Andrew Pratt
    Dec 8, 1998
    3,806
