Rotel RMB 1095 Hum GONE! (1 Viewer)
Scott Goldsmith
I went and ran my cable (TV) through my Monster HTS 2600, and the hum is COMPLETLEY GONE! I just saw someone say that fixed theirs that way so I thought what the hell. I used to have the cable go through the Monster, but when we moved into the new house I didn't hook it back up that way.
Well it's pretty cool if you ask me, no hum AT ALL!! I put my ear ON the grille and hear nothing, I played a DVD and CD, muted the volume, put my ear ON the grille again, NOTHING!! AHHH!! YES!!!!
Just thought I would share my happiness, the wife even said she can't hear it anymore! Now things are EXCELLENT!!!!
Kevin. W
Congrats. I had the same problem and the same solution solved it for me. With the 1095 I found that:
1. Hooking a coax cable between my DVD player and receiver caused the noise. Replace with optical cable solved the problem
2. Same as #1 for hooking Cable Box to receiver
3. Hooking sub to receiver via coax cable caused the hum. Running tv cable through Monster 5000mkII and now my HTPS 7000 removed it.
Kevin
samtbax
