Legairre
- Apr 4, 2000
As some of you may know. My Christmas present is the 1095 amp, but I'm not allowed to open it until Christmas Day(aghhhhhhhhhhhhhhhhh).
I recently had a dedicated 20 amp circuit installed for the amp. While I was out at the Rotel site I noticed the spec sheet says the power consumption for the amp is 1200 watts. http://www.rotel.com/products/rmb1095.htm but the online manual, and I assume the manual in the box says the power consumption is 800 watts. http://www.rotel.com/pdfs/manuals/RMB1095.PDF
According to Rotel the amps real max power consumption is closer to 1600 watts. With an amp the amount of power it draws means a lot depending on how much equipment you already have on a circuit. I know that I'll probably never use the 1600 watts the amp draws, but this info is still inportant.
I wrote Rotel to find out which spec was correct and the conversation is below.
ME
> > I have a RMB-1095. The online owners manual on your web site says the
> power
> > consumption is 800 watts, but the product description from your web site
> > says the power consumption is 1200 watts. I'm just wondering which one is
> > correct?
> > Thanks
> > Legairre
ROTEL
> Dear Legairre,
> I apologize for any inconvenience. The 800 watt spec is correct according
> to regulated standards for typical operation. The 1,200 watt spec
provides
> a maximum rating regarding circuit breaker limitations.
> Best Regards,
> Tim Wyatt
ME
> Tim,
> Does that mean the amp is capable of pulling a max of 1200 watts?
> Thanks
> Legairre
ROTEL
Dear Legairre,
Apparently, there is a typographical error on the web page. That spec
should be closer to 1,600 watts maximum. I apologize for the confusion.
Best Regards,
Tim Wyatt
ME
> power
> > correct?
> > Thanks
> > Legairre
ROTEL
> Dear Legairre,
provides
> Best Regards,
> Tim Wyatt
ME
> Tim,
> Thanks
> Legairre
ROTEL
Dear Legairre,
Best Regards,
Tim Wyatt
