Rotel RB-970BX Amp for $50.00?
Discussion in 'AV Receivers' started by TerryHub, Apr 28, 2004.
  1. TerryHub
    TerryHub Stunt Coordinator
    Jan 6, 2003
    62
    I can purchase a Rotel RB-970BX amp from a guy I work with for $50.00. I have not seen it yet, but the guy seems very picky about his stuff. He says its a 40wpc 2-channel amp. Is this correct? Is anyone familiar with this unit? Should I consider it a steal and take it from him?
    Thanks.
  2. TerryHub
    Jan 6, 2003
    62
    Update:
    I downloaded the manual from Rotel. It's apparenty a 60wpc (8 ohms 20-20K). It was only manufactured in 1994 and retailed $380.00. The guy claims he bought it about 4 years ago.
  3. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    What are you currently using? If you're using a receiver, you might as well pick this up and power your L/R mains which then leaves more power for the rest of your HT setup.
  4. TerryHub
    Jan 6, 2003
    62
    I am currently using a Sony 2ES revceiver which is 100 wpc 20-20K 8 ohms in 2-channel.
  5. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Try it - don't like it, sell it for $!
    I'm in a similar situation, only I have the gear - but no pre-outs.
    I'm going to try replacing my receiver for the sake of that feature alone....
