DanielGM
- Jul 15, 2003
Ok so I have been looking at the specs for both of these amplifiers and having some problems choosing. It seems they are nearly identical, with the only significant difference I could find is that the Parasound uses two power cords in true dual mono style. Otherwise almost all of the specs are nearly identical. I realize they don't make the Parasound anymore, but I wouldn't be considering new in the first place. The retirement of the Parasound makes it difficult for me to hear these before I buy, certainly side by side on the same set of speakers in the same room, which would be the only way I can imagine distinguishing between them with any reasonable accuracy.
I'm certain their are many owners who like their respective amp, so I really need either a factual basis (a certain specification) or someone who has listened to them both. At this point i'm apt to either pick the one I can get a better deal on, or just pick the silver Rotel because it's prettier . Is there another monster 2-channel amp I should consider in the $1100-1200 used price range? (Oh by the way, it's not because I need that much power, it's because I can.)
Thanks for everyone's help
