Rotel Dilemna...
Discussion in 'AV Receivers' started by ArthurJ, Sep 5, 2003.
  1. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    1) Rotel RSP-1066/RMB-1075 $2960 (CAD) Tax Included
    OR
    2) Rotel RSX-1055/RMB-1075 $2800 (CAD) Tax Included
    #1 Pro's:
    "TRUE" Seperates
    #2 Pro's:
    Tuner
    Felxibility (If for some reason I need to sell my RMB-1075, I have power to fall back on)
    Cheaper
    What the heck would you do in this situation...?
  2. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
    How about....
    3) Rotel RSP 1098/RMB1075 ?
  3. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    Are you sure you got my question?
  4. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Arthur I'd go for the 1066 if you don't need the tuner but either way they'll sound extremely similar.
    You likely should check out Club Rotel since that same question has been gone over numerous times there.
  5. Paul Chalk
    Paul Chalk Stunt Coordinator
    Nov 16, 2001
    171
    Getting the 1055 combo gives you a tuner, and the option to bi-amp. Plus it's cheaper.
  6. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    Hey Paul, I'm from Red Deer [​IMG]
    hmmm, what to do...
  7. Paul Chalk
    Nov 16, 2001
    171
  8. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    ArthurJ,
    Go for the 1066/1075 and be done with it.
    Kevin
  9. Nick V
    Nick V Second Unit
    May 7, 2002
    421
    Another fellow Albertan here!!
    I'd say go for the 1066 if you're the type that obsesses over little things. If you go with the 1055, you might always be wondering if the 1066 would have sounded just a bit better.
    If you're all about value, it's obvious which one you should pick. If you can set it up once, tailor the settings and be content to simply listen, you may want to go with the 1055, as I don't think there is a significant sonic difference.
  10. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    Just wondering if it has a dedicated headphone amp...thanks!
  11. Andrew Pratt
    Dec 8, 1998
    3,806
  12. Andrew Pratt
    Dec 8, 1998
    3,806
    No it doesn't. You can add a much better head phone amp to any receiver/pre amp for not that much money. There was someone asking that same question the other day if you want to read their responses.
  13. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    Arthur, I've combined your two Rotel threads.
    M.
  14. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    I concur with Paul in post #5. That will give you the most options. Even if you don't biamp all speakers, you could at least do it with the mains (and maybe even center too), you would still have 2 extra channels for full on 7.1, and/or still have 2 channels leftover for multi room, etc. Win/win situation all the way around.
    Besides, isn't the pre/pro section in the 1055 supposed to be the same as the 1066 anyway?
