Rotel 1070's vs Bryston B60 vs Blue Circle. Best deal for less than 1.5k?
Discussion in 'Archived Threads 2001-2004' started by Walt Park, Dec 20, 2002.
  1. Walt Park
    Walt Park Stunt Coordinator
    Nov 14, 2002
    115
    Hello, I'm looking at doing a 2 channel for the living room, and went to the "boutique" last night to check stuff out. I was looking at the rotel 1070pre/pro but the sales guy was really trying to steer me to the Bryston B60, which sounded better, but was playing on B&W CM4's as opposed to the rotel hooked up to 602's. Then there's the Blue Circle CS, which reviewed really well at soundstage! in that price but I haven't heard them.
    I liked that you could separate the pre/pro on the bryston, but apparently you can pre out on the blue circle for an extra $75.
    The rotel combo will have more power, but I probably wont use it all anyway.
    So what should I get?
  2. Brandon Blair
    Brandon Blair Stunt Coordinator
    May 28, 2002
    96
    If I may, I'll give you a couple of other options you may want to consider. Not that I think that there is anything wrong with any of the stuff you're looking at. But, these are a couple of brands I personally prefer that you may want to try and listen to.
    Audio Refinement
    Complete Integrated Amplifier
    2 channels X 50 watts
    retail = $995.00
    www.audioplusservices.com
    Moon, Sim Audio
    i-3 Integrated Amp
    2 channels X 100 watts
    retail = $1,595
    www.simaudion.com
    Good Luck,
    Brandon
    [email protected]
