Rotel 1066 vs 1068
Discussion in 'AV Receivers' started by Patrick_Tysell, Jun 2, 2004.
  1. Patrick_Tysell
    Patrick_Tysell Auditioning
    May 31, 2004
    7
    What are the main differences between the Rotel 1066 and the 1068?
    I am probably going to snatch up a 1066 because of thier low price now that the 1068 is out but I would like to know if there is any compelling reason that i should get the 1068.
    I am having trouble finding tech documentation on teh 1066 on Rotel's web stie.
    Thanks for the advise.
  2. Patrick_Tysell
    May 31, 2004
    7
    Oh and also should i be conserned lack of DVI or resolution problems such as upconversion/downconversion of resolution?
    I am assuming that the 1066 is able to accept 720p HDTV "signal" and not just "EDTV"
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Check out the Rotel forum on www.htguide.com.
    Also, a review of the 1068 in the latest SUAV (the old SGHT). From both of those sources, I get the impression that the 1068 is closer to the 1098 re performance than the 1066.
  4. Patrick_Tysell
    May 31, 2004
    7
    Ok so let me ask one more questions as i am some what new to this, is it better to get one large amp block to drive all my channels or say a bunch of stereo amps to drive my channels.
    I am thinging of going with the RSP-1068 and some RB-1080 for the from channels and the RB-1070 for the rest or i could just go with the 1095.
  5. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Patrick I'd suggest you go with a 1080 for the fronts and a 1075 for the rest. That combo is the most common setup and is the best mix for HT and music.
