Jeff Kohn
- Dec 29, 2001
OK folks, I did some more testing today, and there is bass management on the 6.1 inputs. Here's my setup and results:
I have tower mains that are capable down to about 35hz. All speakers are set to "small" with an 80hz x-over. I've never flashed my 1066 with a software upgrade, so I'm assuming it has the 1.35 software since the version number is not displayed in the setup menu. I was testing using my HTPC, playing WinAMP via the analog outputs. I had only the front l/r channels of the 6.1 inputs hooked up.
First, the tone controls are apparently analog, because they are indeed active on the 6.1 inputs, just like the with Outlaw 950.
Second, although you can turn CinemaEQ on and off, it doesn't seem to have any effect 6.1 outputs; additionally, although you can select various surround modes such as DPL2, DTS:Neo, etc, they have no effect and you still only get 2-channel music. If you ask me, this behavior is a bug, because if a certain DSP mode is not available you shouldn't be able to select it, and the speaker indicators should show the accurate speaker configuration for the current sound format. In other instances, the 1066 is more consistent; for example, if I feed it a 24bit/96khz PCM digital signal from my HTPC, all DSP modes are disabled (you can't even select them), and you're locked into 2-channel stereo. I think they should do the same thing when the 6.1 inputs are enabled. Hopefully they'll address this in a software update as it can really lead to some confusion.
Finally, I discovered that I am definitely getting subwoofer activity on the 6.1 inputs. So the claims that the 1066 has straight passthrough with no bass-management are not true. Since the 1066 doesn't have any type of manual switch for an analog x-over like the Outlaw 950 has, I can only assume that with this configuration you're getting "double-bass". Now the 1066 does at least have per-mode subwoofer settings, so it should be possible to lower or completely disable the subwoofer from the "Sub Level" menu for the 6.1 inputs.
I think we need to get some clarification from Rotel on how this works, exactly. Do the mains truly get a full-range signal from the 6.1 inputs when set to "small" with a subwoofer? If so, then lowering or completely disabling the subwoofer for that mode is probably OK, but I would like to get confirmation from Rotel.
