Bobby C
- Dec 23, 2003
Hi,
I started building out my HT a couple of months ago, but of course it got put on hold because of another project. I'll be starting up again in a few weeks, but have a question on ventilation of the room.
This room is in the basement, only 1 (small) window in a 12x20' room, 7' high. Currently the room receives no direct ventilation, but the forced air (heat & A/C) for the upstairs is routed through the ceiling joists. Right now there are 2 supply and 1 return in that could easily be tapped into to provide room ventilation.
I could put more in if needed, however I won't be adding a separate control for the room or basement. Any suggestions on whether this I need more ventilation? The return is near the front of the room, as is one of the supply ducts. In addition, the 2nd supply is about 2/3rds towards the back of the room.
Any suggestions are appreciated!
Bob
Bob
