Chris PC
- May 12, 2001
My basement room is funky. It has two concrete walls adjacent one another, and a concrete floor (with underpad and carpet), (the three concrete surfaces form a corner) a drop ceiling of ceiling tiles with egg cartons underneath, and two walls made of flimsy panelling. The panel walls have no drywall and therefore, I believe, they do not act as true barrier walls. The rooms dimensions are: 14 foot 3" x 12 feet. Drop ceiling at 7 feet 1". Wooden floor/ceiling above at approx 8 feet (so 12 inches of space above the drop ceiling).
Here is what I noticed with my older stereo, with 50 watt per channel amp and 8 inch woofer Boston Acoustics acoustic suspension speakers. When I used to have my stereo along one of the flimsy walls, and I sat near one of the concrete walls or the corner of the two concrete walls, I noticed that there was more low bass when I sat there. Duh. No kidding? Well, why is it now that I have my new speakers and subwoofer along the concrete wall, that sitting out by the flimsy panel wall, I don't get the same bass response. It seems to me that listening position in a room is as important, or more important than where the speakers/subwoofer are. You'd figure with the speakers/sub along the concrete wall that bass response would be good, but its not necessarily so. Another noted characteristic of my bass leaky room is that when I'm in the other end of the basement, effectively in another "room" (separated only by the flimsy panels), near the other concrete walls of the basement, I can hear and feel bass possibly better than at my listening position back in the room where my equipment is playing? So with the older system, I had the enhanced bass of sitting by the concrete walls or concrete corner. I didn't set up my new system the way the old setup was. I believe I noticed though, that when I had my old system setup the way my system is now, it had less bass. I intend to find and purchase a BFD to EQ my listening position and do some tweaking, however, I still wonder about the flimsy walls. Here is my question.
Should I replace the flimsy panel walls with proper drywall walls? This would create a more solid room. Would this complicate things or improve things or is there no way of knowing until I actually did it? Ie the results would be totally unpredictable and likely involve standing waves etc.
Why don't I just re-arrange my room so I have my listening position near the concrete walls again? I could try that, and I might, but it would be difficult and involve extreme re-wiring and re-configuration of the room.
I was thinking of doing some testing, and here is how! I could bring my receiver, CD and DVD player, speakers AND subwoofer all up into the room directly above me and experiment to see what things sound like in there. The room above is totally structurally sound, like a normal room with regular wood or drywall walls. almost identical in shape to within 2 or 3 inches, EXCEPT for the closet! It would be a huge hassle, but I think I would learn something from this experiment.
So should I replace the flimsy panels with true structural walls made of drywall?
thanx for any ideas
thanx for any ideas
