Kirk Mango
- Jul 8, 2002
I have posted questions regarding my room equalization in the past, however, I have something else I would like to ask regarding the numbers I have. First let me give some background again. I have a B&K Ref 30 and am using the -42dB test tone generator to test my room nodes and bass response (reference is 0 on this unit). This test tone is the lowest one available. Their are two other louder tones but for comforts sake I choose the lowest one. My mains are set to large (Mirage OM5's, rated down to 22hz +/-3dB) because I am using both the high and line level connections to my Rel Storm subwoofer. All speakers are powered with B&K 200 watt per Channel amps with the mains having a sepperate 220 watts per Channel B&K amp (the OM5's also have their own built in 250 watt amp per speaker). All other speakers are set to small with the crossover on the Rer 30 set to 80hz. Sub is corner loaded and behind a 60" RPTV. I should also point out that I have a filter set, on my Ref 30, from 40hz-50hz because of a room boost at this level. This boost had the original readings at this hz level at/above 80hz. The first number is the Hz, the second number is my original reading with only the filter applied, and the third number is after adding in the RS meter correction factor. My readings with the test tone are as follows:
Hz, Orig/dB, After RS/meter Correction
2064 72
2266 73
2472 77
2671 76
2872 76
3071 75
3270 73
3470 72
3670 72
3871 73
4073 75
4274 76
4474 76
4674 76
4875 77
5074 76
5271 73
5472 73
5673 75
5874 75
6076 78
6276 77
6476 78
6677 78
6876 78
7076 77
7276 78
7476 78
7676 78
7875 77
8074 76
8272 74
8471 73
8669 71
8868 70
9067 69
9266 67
9463 65
9659 61
9856 58
10058 60
My Question is why is there such a big Drop in dB after 80hz. Is it because the sub is not picking up any bass from my center and 4 surrounds after 80 hz and these speakers are now expected to play this tone. If this is true then why as I get beyond 100 hz do I notice that the dB readings start to rise until they are in the middle to upper 70's again. What do you think? Also, how close to flat is my response considered. I am under the impression that if you can keep all dB readings within a 10 dB span you are doing very very good. Is this true? Below 80hz, using the correction factors, I am easily within this range. In fact I am within 6dB from 80 hz down.
KM
2064 72
2266 73
2472 77
2671 76
2872 76
3071 75
3270 73
3470 72
3670 72
3871 73
4073 75
4274 76
4474 76
4674 76
4875 77
5074 76
5271 73
5472 73
5673 75
5874 75
6076 78
6276 77
6476 78
6677 78
6876 78
7076 77
7276 78
7476 78
7676 78
7875 77
8074 76
8272 74
8471 73
8669 71
8868 70
9067 69
9266 67
9463 65
9659 61
9856 58
10058 60
KM
