Room Acoustic Treatment Help (reflection points, positioning of rug)
Discussion in 'Home Theater Projects' started by Thi Them, Aug 3, 2004.
  1. Thi Them
    Thi Them Producer
    Apr 20, 1999
    3,649
    I recently moved my home theater from the family room into a 10x12' vinyl-tiled bedroom, with the actual theater area being 9 (from left front speaker to the right front one) x 12' (from screen to seat). I tested some DVDs the other day, and the sound is really "lively" compared to the theater's previous location. Mainly, I'd like to reduce the echoes I am experiencing in the bedroom.
    I've read of two ways to treat a room for absorption: covering the reflection points or creating a ring around the room near ear level. Which is the better method for me, since I will be watching many movies in 5.1?
    As for the floor, I'd like to cover it with a rug. How much of the floor should I cover? There is a bed on the right side of the room, the side of which is 1.5' into the actual theater area near the right front speaker. Should I have the rug go underneath the bed?
    Thanks.
    ~T
  2. Ben Mecham
    Ben Mecham Agent
    Jul 20, 2004
    25
    While I definitely think that it is important to do some acoustic dampening in a room for echo purposes, I think too much can cause an unnatural hush. I would do the rug idea for sure - probably not the whole room though. And the reflection point acoustic panels have a good effect, and are more aesthetically pleasing than a "ring around the room", IMO. I think a lot also depends on the variety and locations of listening positions -- if it is sporadic seating, such as bean bag chairs, etc, then panels on specific reflection points won't be much of a help. On the other hand, if there is just one couch, reflection points can be located rather easily and dampened accordingly.
    Hope this helps,
    -Ben
