Hello,
I'm trying to cut down on reflections in my room.
I have a 7.1.4 system. For the sides and back walls I'm thinking of using a 1.5" thick mineralwool - 80 (8lbs).
When I do pink noise testing, I can hear the back speakers off the front wall, which totally ruins the effect.
Behind the AT screen, I can put some material, but only 1/2".
Any recommendations on what you would do?
I see 3/8" tiles type absorbers or a rug pad that I could hang on the wall...
Any advice would be appreciated.
