Riser - additional height
Discussion in 'Home Theater Projects' started by SamCK, Dec 28, 2003.
  1. SamCK
    SamCK Agent
    Nov 24, 2003
    41
    We recently built a riser (4 by 8)made out of 2X6 on 12 inch centers, stuffed with insulation, 1/4 inch plywood on bottom, and two 3/4 inch sheets on top with roofing felt sandwiched between. Very sturdy, but I now realize I need a little more height. I'm wondering about using a sturdy "sofa leg" type of support to give me that extra 3 inches or so. Will it interfer with sound or anything?
  2. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,476
    340
    9,110
    Cees Alons
    Sam,
    No it won't. But you have to construct it right: no tilting or other movement (the floor may be uneven!)
    Good luck.
    What will be the total height?
    Cees
  3. SteveLeach
    SteveLeach Stunt Coordinator
    Nov 19, 2003
    159
    For 3 more inches of height, I think I'd go with 2x4s, framed like you did the 2x6s and another layer of 1/2" ply on the bottom.
