right way to measure port length
Discussion in 'Archived Threads 2001-2004' started by Wendell, Nov 6, 2002.
  1. Wendell
    Wendell Stunt Coordinator
    Jul 23, 2002
    96
    do i measure from flared end to flared end or the center tube?
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,751
    482
    9,110
    Measure end to end, and then subtract 1 inch from the measured length to get the effective lenght.
  3. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    In other words, you trim the center tube to 5" shorter than the effective port length
    (because the flares add 6" to the length of the center tube)
    Remember to factor in the number of ports used when calculating the port length.
    Also keep in mind that if you're making an Adire Audio sub, they usually tell you the length of the center tube. So if they say 11", then that's how long you make the center tube for the port.
  4. Brett Loomis
    Brett Loomis Stunt Coordinator
    May 9, 2001
    142
    Chris, I was just getting ready to cut my ports for my Tempest 214L.....
    My center tube should be 11" before assembly correct?
    Thanks, Brett
  5. Chris Tsutsui
    Feb 1, 2002
    1,865
    If it's an adire alignment 214L tuned to 15.4hz, then the center tube should be 11"
  6. Brett Loomis
    May 9, 2001
    142
