KerryC
- Aug 3, 2002
I need help please!
I recently purchased a house that has a room that is pre-wired for a home theater. This includes wiring for an overhead projector.
The three wires that are routed to the projector site are an "RGB+H/V", S-Video, and CAT 5E. The projector I am considering buying does not have an RGB input, only Component, S-video, Composite and DVI. Is there any way to use the RGB cables in a hookup like this? (I will have a progressive scan DVD player and hope to have HD television through my cable soon, so I don't want to settle for just the S-video.)
My other question relates to the other end....I would like to connect my video sources to an A/V receiver and output them from the receiver to the projector. I've noticed some of the better receivers have Component switching as well as S-Video and Composite. What about RGB? If I elect to purchase a projector with RGB inputs (ie Sony VW12HT) will I be unable to connect the RGB cables to a receiver?
Lastly, why would a CAT 5E wire be routed to the projector site?
Thank you for any help, I am pretty confused at this point.
Kerry
Kerry
