RG-6 for speaker wire
Discussion in 'Home Theater Projects' started by chrisMU, Jun 10, 2005.
  1. chrisMU
    chrisMU Auditioning
    Jun 9, 2005
    Does anyone know if you can use RG-6 for speaker wire? I have 14 guage wire installed(new construction home), but I am afraid of interference with electrical lines. I would use RG-6 with the RCA compression fittings. Does this sound like a good idea, or not?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,222
    58
    9,110
    Corpus Christi, TX
    Wayne
    It would be virtually impossible to connect RG-6 to a receiver’s binding posts, Chris. Not to mention the center conductor is only 18 ga. or so.
    The 14 ga. wire you’ve already installed is fine. Interference with speaker wires is a virtual non-issue, especially if you avoid running it directly alongside electrical lines.
    Wayne A. Pflughaupt
  3. Dennis Gardner
    Dennis Gardner Stunt Coordinator
    Dec 12, 2002
    206
    If you are worried about interference, you might try a Cat5 based speaker wire setup. TNT Audio has a great DIY section on cabling.Triple Cat 5 Speaker Wires
    Just a thought,
    DG
  4. Tom Rosback
    Tom Rosback Stunt Coordinator
    Jun 7, 2000
    119
    Chris,
    If you're using the normal 14 GA low voltage wiring, two conductors, twisted, in a vinyl jacket, you're good to go.
  5. Leo Kerr
    Leo Kerr Screenwriter
    May 10, 1999
    1,698
    I'd only worry about it if I was doing a long run against a line-voltage, high current power cable that was SCR-dimmed to about 50%. Speaker-levels are pretty hard to muck up.
    Leo
