RG-6 for long subwoofer cable?
Discussion in 'Archived Threads 2001-2004' started by Thomas F, Jan 2, 2003.
  1. Thomas F
    Thomas F Stunt Coordinator
    Sep 6, 2001
    111
    A friend of mine has purchased the Onkyo S655 HTiB and needs to run a long subwoofer cable through the attic to the sub that has to be located behind the couch due to the WAF. This could possibly require 40'-50' of cable. He is on a budget and a local Tweeter manager suggested that he could use a solid core coaxial cable such as RG-6u. Would this compromise the signal reaching the sub and consequently the sound? Has anybody tried anything similar?
  2. Guy Usher
    Guy Usher Supporting Actor
    Oct 20, 2002
    780
    At one tome I replaced every interconnect I had with RG-6 Quad shielded cable, loved it only problem I had was stiffness. Heavy Mic cable works well and is more flexible, may be a little more difficult finding big enough wire. . .
    Another option is to buy interconnect wire and good terminators in bulk to make your own, try MCM Electronics, or Parts Express
  3. BradJudy
    BradJudy Stunt Coordinator
    Sep 25, 2002
    211
    I use stranded core RG-6 (Canare LV-77S) for all of my interconnects including my subwoofer. It works great.
  4. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    As long as it is true RG-6. You can get cheap coaxial cable that is meant for cable TV, but that stuff is no good.
  5. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    RG6 is the way to go for the sub. You can also get one 20' Radio Shack Gold Stereo Cable, pull them apart to split the line, couple them with a Radio Shack connector (about $2) and create a 40' cable. If you need more get another coupler and some more cable, but truth be told- I would only split the line once and only as long as I knew that the cable would never ger pulled on.
  6. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I use this approach in my current setup for my second sub with a 50' run of RG6 cable. I also used it in my old HT room as well (a 40' run).
  7. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
