Is this all I need to run my own cables? stripper, crimper.
I would like to redo my cable and Dish lines with better cable and connectors, will these tools work with most coax cable and crimp connectors?
Greg
Greg,
I’m not a fan of cheapie RF crimpers, but the one you’ve chosen looks pretty good for the price. Keep in mind that it will not work with RG-6QS, although that shouldn’t be a problem.
If any of your new connections are outdoors, I suggest using this weather boot from Radio Shack.
Wayne A. Pflughaupt
Greg, You can also buy a set of dies for RJ11/45 (check the dropdown menu on the crimper page and look for the #360-048 REPLACEMENT DIE) and you'll be set for network/phone cabling as well. Those dies are incredibly cheap as the set I purchased at Fry's was around $35.
Sorry about that guys, I don't even know how that resistor came up with a simple cut and paste.
Correct link: http://www.partsexpress.com/pe/pshow...360-680&DID=7.
The other dies for crimping insulated and non-insulated terminals could definitely come in handy.
Plus it has been known that this crimper frame will accept the Canare dies, in case you ever go to making Canare cables.
