Rg 1 problem on multi Rg player (underworld)
Discussion in 'DVD' started by stewart borland, Jan 24, 2004.
  1. stewart borland
    stewart borland Stunt Coordinator
    Jul 16, 1999
    205
    I've only ever had this problem once before and I've forgotten the solution :b
    I can't even remember what disc it was last time, but now Underworld won't go past the Region 1 only screen although I have a multi region player (at least 50% of my discs are Region 1) can somebody help please?
  2. Judy Y
    Judy Y Stunt Coordinator
    Feb 27, 2000
    119
    I have read that there are many region one discs, (RCE, I think they are called) that will not play in REGION FREE players and you need to switch your player back to region one to get it to work. Many region free players have a menu to allow you do that.
    Hope this helps.
  3. stewart borland
    Jul 16, 1999
    205
    I don't have a 'switch' as such, it's all done automatically (well usually!!) you just pop in a disc and it plays.... anybody else??
  4. Christian P
    Christian P Stunt Coordinator
    Feb 27, 2003
    87
    Hi!
    My player switches automatically too, so if I have a RCE disc, I have to insert a normal region 1 disc first, load it up, then eject it and put in the RCE one. Try that.
    Regards
    Chris
