Evan Mann
- Oct 14, 1999
I am hooking up some equipment for a friend of a friend in their kitchen. The kitchen was remodelled and there is a TV in a center island on a lift. The source components are across the kitchen in another area.
For some reason, the only connection between the center island TV and the source components is a single coaxial cable. THe center island TV has composite and component inputs, as well as a coaxial antenna input
The source components are a BD player and a DTV HD DVR. I need to be able to get both of those sources to display on the center island TV. The only option I have found thus far is a multiple source modulator. Terk has a 4 input modular with IR remote control capability, which looks like it will do the job nicely. I can use RCA A/V output from the BD player and the DTV HD DVR into the modular, and then the modulator to the TV.
I realize the quality of signal going to the center island TV will likely be standard DVD quality, if that, but that's fine.
What I'm not sure about with using an RF modulator, is this: With the modulator work if I only connect RCA based sources to the inputs on the RF modulator, and then coaxial out from the modulator to the TV?
It's unclear to me if the modulator will work without having a coaxial based antenna input the modulator.
Outside of using a modulator for this particular environment, if anyone has other suggestions, I'm open. Wireless transmission is the only one I've come up with, but all the wireless transmitters at reasonable prices only accept 1 RCA A/V input, and I'd need to get two into the transmitter some how.
