Donald_S
- Oct 19, 2003
I was looking for a solution to having some of my a/v equipment automatically power off when I shut off my receiver. I got a suggestion from DavidLW to look at the Bits Ltd. Smart Strip product.
The idea behind the Smart Strip is that there is a controlling outlet. When that outlet shows a big drop in power draw (i.e. it's powered off) it shuts off the 6 switched outlets on the strip. When power jumps up, it powers those devices on.
I ordered one and here is my take on the product:
The strip is one of the most well thought out ones I've seen. It has 10 outlets altogether, 1 controlling, 3 other hot, 6 switched. 1 of the hot outlets and 3 of the switched ones are spaced for transformer plugs, so your really get 10 usable outlets.
I decided to plug in my receiver as the control, my DVD player hot, and my TV, subwoofer and small backlight as switched. Initially the control didn't power off anything, but making a small adjustment to the sensitivity of the trimmer did the trick. The power on/power off levels differ by 20%, so that you can't get a 'cycle' of powering on and off going by setting the trimmer right at the threshold.
I'm pretty darn pleased with the result. Now my subwoofer that I was always leaving on gets shut off, and I don't have to crawl behind my TV to turn on my theater back light.
The specs on the strip are pretty good. It can handle up to 15 amps, has the usual lightning strike protection, and even has some line noise protection. It has a $30,000 equipment meltdown warranty as well.
Some people won't like the idea of completely powering off a/v equipment. Some say that constant heat stresses components, others say that power up and down will. I think frankly both are true to some extent. But you can choose which ones are connected hot with the Smart Strip and choose your poison. Frankly I think the convenience and power savings make this a great deal. Especially since the strip is only $30. Compare that to any Monster strip, even the ones that don't have noise suppression circuits.
You can order one at:
http://www.bitsltd.net/smartstrip/home2.htm
Donald
Donald
