Review of PB2+ on hometheaterspot
Discussion in 'Speakers' started by ScottCarr, Oct 31, 2003.
  1. ScottCarr
    ScottCarr Second Unit
    Jan 28, 2003
    459
  2. Jon_Krug
    Jon_Krug Stunt Coordinator
    Sep 4, 2003
    56
    someone started a thread about another review for the pb2+ less than a week ago. for some reason i think it was deleted. does anyone know why?
  3. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Well, I'll post here since it sunk in when I read this review. The PB2+ has stereo RCA jacks in and out, with the crossover in the sub. Any benefit to say, running the mains "large" in the pre/pro, "no" sub, and then using the crossover in the sub?
    Oops, one probably downside anyway: DVD-A/SACD via the 5.1 analog inputs in the pre/pro. The pre/pro won't do LFE redirection to the mains even if I have "no" sub in the pre/pro. I don't think the player will either, even though it should. Well, for kicks, any advantage if I could do that? I'm thinking mainly phase, but it's not so hard to get phase correct the way most of us do it now (letting the pre/pro do the x-over).
  5. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    That article was great. Having been thinking about replacing my own sub in a 4300 cubic foot room and my only SVS audible reference is a Twin 25-31 CS+ Setup, this comparison with the 25-31 CS ultras seems to have said that the pb2+ was better so I shouldn't be too worried about being dissapointed if I go that route.
    If the Pb2+ Widescreen review article is able to be had via the magazine, which WSR is it available in?
  6. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Shane:
    Issue 78, November 2003.
  7. Jon-C
    Jon-C Stunt Coordinator
    Mar 18, 2003
    95
    The thread was bumped over to the WIDESCREEN REVIEW forum...
  8. Edward J M
    Sep 22, 2002
    2,031
  9. Kevin C Brown
    Aug 3, 2000
    5,712
    Ed- It's not the BM from the player that had me concerned. In other words, if I wanted to do the crossing over within the sub, then I can't have any separate LFE signal. No .1 of the 5.1. The LFE has to be redirected into the mains so I can have the sub do everything. DD and DTS are easy, because the pre/pro will redirect the LFE to the mains if I have "no" sub selected. But most players won't redirect the SACD/DVD-A LFE even if I have "no" sub selected, and most pre/pro/receivers won't do it either for the 5.1 analog inputs.
    I was just curious, because Vandersteen has a more seemless way to integrate their 2WQ sub and their mains with an included external crossover, but I agree, in this case probably just easier to let the pre/pro do it. The complete set of L & R inputs and outputs in the PB2+ brings up that flexibility too.
  10. Steve Morgan
    Steve Morgan Second Unit
    Nov 10, 1999
    328
    Farm in Kansas
    Steve
    If the review of the PB2 plus was a good review, I wonder if my PB2 Ultra is of the same ilk? I would assume it would be, with just a little more extension and output. Just curious.
    Steve
  11. Ron Stimpson
    Ron Stimpson Stunt Coordinator
    Jul 19, 1998
    199
    Steve,
    Probably a tick stronger down deep and with greater overall output (those TV-12 Ultra woofers are very capable) but I wouldn't buy it strictly on that basis. The wood cabinets (which are unique to the PB2-Ultra, they aren't just veneered versions of the PB2-Plus box) and the parametric EQ we're planning for the PB2-Ultra will be the most apparent differences.
    Ron
