Jack Briggs
- Jun 3, 1999
Don't really know what to make of this.
As some of you know, NASA has issued competitive bids to three aerospace companies to offer design proposals for a manned Orbital Spaceplane that would serve as the primary crew-transport vehicle to and from the International Space Station (with one permanently docked at the ISS as a Crew Rescue Vehicle). OSP would itself be reusable, but be lofted into low Earth orbit aboard an expendable launch vehicle. The vehicle would complement the present STS, not replace it.
Eventually, the Space Transportation System (aka, "space shuttle") itself would be retired (unfortunately) almost two decades from now by a new-generation reusable manned heavy-lift spaceplane. I say "unfortunately" because it is suicide to consider using the present system that long; a replacement vehicle should have been approved long ago.
However, given the entrenched reluctance to boost NASA's budget to above susbsistence levels, a new proposal is being floated at the space agency: an uprated, improved version of the single-use-only Apollo Command/Service Module.
That's right. In a clear move back to an earlier era, the U.S., under this proposal, would return to one-time-use-only spacecraft with ablative heat shields and water recoveries (i.e., "splashdowns").
Talk about vision. The troubling part is that such a scaled-back manned-spacecraft system would be forced on NASA because of its ever-present budgetary woes.
Way I see it, if this nation continues to regard the space effort with such indifference why not just scrap NASA altogether and parse out its science programs to other government agencies? One either conducts a manned space program with all thrusters firing or doesn't do it at all. One thing's for sure: I won't be seeing a manned mission to Mars in my lifetime. Neither will most of you.
Read the sad news here. (A little technical, but what the hey.)
