Results of my blind cable A vs. B test
Discussion in 'Archived Threads 2001-2004' started by Shion_ca, Sep 5, 2002.
  1. Shion_ca
    Shion_ca Stunt Coordinator
    Aug 17, 2002
    89
    Hello All,
    Thought I'd share the following. When being asked if I' car eto invest in decent interconnects for the Musical Fidelity Amp/Preamp I'd just bought, I said I didn't have the money now but would consider if I could get a good demonstration of their worth. So with the exact components I had A3 CR plus a set of Meadowlark Heron i's, a Mark Levison CD player, Cardas neutral reference speaker wire and Cardas neutral ref. source to pre. We switched between my radio shack generic red/green/yellow av interconnects and a $400 (can) Harmonic tech offering. I listened to the opening of track 2 on Enya's sheppards moon (the one with Lothlorien on it) Cd three times, then left the room and he either swithced or didn't switch the cables. I could only ask the sales guy to do this 8 times but in those 8 times I was able to pick each time which was which and then personally looked over the back and confirmed myself. The $400 sounded thicker in the highs and mids and appeared to have more "space" between the instruments. I did have to listen 3 times though to confirm, after each switch I put the Radio Shack back on and reaccustomized myself to their sound. It does take some listening though and wasn't entirely obvious but I think if you know what to listen for you'll note a difference.
    I was very disappointed as I'd hoped that they'd sound the same ; ) In any case for Chu et al non believers (which formerly included me) get a really good setup of every component (like the one I described, I'm not talking monster speaker wires or interconnects I'm talking the higher end Cardas and Nordst) and then swith the components betwee the source and pre with Radio Shack and say Cardas etc. If your honestly willing to buy, any high end speaker store should be agreeable to the experiment. I'd like those of you who are naesayers to go out do this with really high end gear and tell me what your results are. I do believe there is a noticable difference between really base av wire and really high end cable.
    So for what it's worth these were my findings and I encourage all of you to go out and do the same before you continue to debate the subject. Just go see for youself.
  2. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    Glad you found out for yourself. That's my stock answer nowadays.
    Be prepared to be told your wrong and the test wasn't accurate and that lamp cord makes a fine interconnect. [​IMG]
    Thanks for the info!
  3. Shion_ca
    Aug 17, 2002
    89
    Has anyone else gone out and done this and would like to share their experiences?
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    well a good effort however......
    i'd have had someone there watching the salesman and......
    i'd have ensured the levels at the speaker terminals were matched using a VOM...
    but if it makes you happy...[​IMG]
  5. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    Theoretically, it should be easier to tell differences between interconnects than between speaker cables. At least, so I believe.
    Thanks for posting your experience, this is definitely interesting.
  6. Brian OK
    Brian OK Supporting Actor
    Aug 29, 2000
    550
    Thanks for the post.... and for being candid.
    BOK
  7. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    i'm surprised chu gai didnt post another small novel about how cables dont matter. thats precious bandwidth youre taking up, especially when nobody bothers to read it.
    CJ
  8. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    8 out of 8 is a rather remarkable score and Christ, you should read more carefully what I've written in the past about how to properly conduct tests. i always thought novels, which are looked upon as fictional tales, were called white papers [​IMG]
    having a salesman conduct the test is like having Charlie Sheen swear that Britney Spears is a chaste young woman.
    nonetheless I don't begrudge Shion's investment.
  9. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
  10. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
  11. John Royster
    Oct 14, 2001
    1,088
    lee,
    YGPM - re box sets
  12. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    My older son, who knew her when she was just a little Spear, nary more than a stilleto, has stated she is a deeply spiritual person. When I asked how he knew, he told me that the one night they'd spent together, she kept yelling out 'Oh g*d'. I'm glad he laid that matter to rest.
    Now you ought to know better Lee about making efforts to control variables and letting the fox guard the chickens!!
  13. Christ Reynolds
    May 6, 2002
    3,597
    CJ
  14. Eric_Lakes
    Eric_Lakes Agent
    May 2, 2002
    36
    Shion,
    It's great that you took the time to test this debate for yourself. When I first got into HT, I took a listening test also. I took 2 different cables and plugged them into the left and right and turned the balance from left to right... and boy was i surprised!!! My virgin ears heard the difference. So for years I spent the 10% rule on cables and I told everyone about my test results. I was very confident until I got to know more about "STEREO". That revelation blew away my original test results!!! So I took anther test and disappointed as I am, my ears are not golden [​IMG]
    Knowing that a salesman administered the test to you, do you still feel that your test results are accurate??? (BTW, the markup on cables are where salesmen make the most $$$)
  15. Bob Sheen
    Bob Sheen Stunt Coordinator
    Apr 14, 2002
    97
    Hi Eric,
  16. Eric_Lakes
    Eric_Lakes Agent
    May 2, 2002
    36
    Bob,
    With STEREO sound, there are different signals going to each speaker. I don't remember what sound track I was listening to, but the difference I heard that day might have been contributed to this. So since the test was invalid, I could not use those results as the basis of my opinions. That forced me to re-think, and so I decided to take a more controlled listening test. In the second test, I could not distingush any difference. I still have hope... that's why I said that I don't have "Golden Ears". Because I cound not tell the difference, I have to be kinda skeptical.
    If there was some with a "Golden Ear" out there and I was part of setting up the test and administering it, and that person could tell the difference, then my faith would be fully restored. Until then, I can only go by what I have tested myself.
  17. RobertR
    RobertR Lead Actor
    Dec 19, 1998
    9,955
    347
    9,110
    The methodology used by Shion is of course invalid, since it was not a true double blind test. What was really needed was a THIRD person doing random switching while having no contact WHATSOEVER with Shion OR the audio salesman.
  18. Bob Sheen
    Apr 14, 2002
    97
  19. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    wow interesting stuff.....would you be against moving up the cable chain to see when the differences start to cease? how bout comparing with the AR pro series?
  20. John Royster
    Oct 14, 2001
    1,088
