Patrick_J
- Dec 4, 2001
This is a call to arms for all of you buying, selling and trading DVDs through the mail. Having purchased my share of discs via eBay, Half.com Amazon, Deep Discount and others I must state that one of the most frustrating aspects of buying DVDs though the mail is the occasional rattler.
Rattlers, for those of you who have never experienced the joy of having your mail person deliver new movies in subzero weather, is a DVD disc which has some how dislodged itself from the retaining hub of the DVD case and spends its journey to you getting marred and scratched on everything inside the case; especially said hub. Last month I was the lucky winner of a sealed Criterion title on eBay. The disc arrived factory sealed as promised but when I opened the case to view the movie, the disc surface was badly marred because it had become loose within the case. Fault would be hard to place and useless anyway (the disc still performed flawlessly), but ultimately I propose the following for everyone mailing/shipping DVDs across the country or world:
1. Take a thin layer bubble wrap or the protective foam that most electronics come packaged in. Those of you DVD addicts on tight budgets can even split an overused bubble padded envelope in two.
2. Take a ruler and measure out a rectangle 5 inches wide and 7 inches long. The rectangle doesn’t have to be completely square and it doesn’t even have to be exactly 5” x 7” so long as it isn’t larger.
3. Repeat the process to coincide with your DVD mailing volume for the next month.
The next time someone purchases or trades a DVD with you, be sure the disc is in securely locked into place and then lay one of these sheets inside the case prior to closing it up. If the case won’t close don’t force it, use a thinner layer of material. It also important that you protect the outside of the DVD case as well, although these can be replaced affordably (with the exception of the cardboard crapper cases). Encourage those who receive your safety sheets to use them when they send DVDs to others. The sheets are light weight and don’t add anything to shipping costs and should assure safe arrival of the DVDs.
For more tips for DVD addicts, visit my Yahoo Group at Martha Stew...
http://groups.yahoo.com/group/DVDs-in-Demand/
-pjc
-pjc
