Jay H
Here's your chance to help out a CompSci guy fix a tuner (an HK Citation 23 tuner) who's backlit LCD screen died because the little light bulb burned out. I opened up the whole unit and found the dead lightbulb and it's attached to two poles on the main PCB, one of them has a resistor inline witht he wire that leads to the bulb, the other side of the bulb is just a straight wire. I'm trying to figure out what kind of lightbulb (volts and wattage) to replace it with. An email to HK hasn't come up yet and I'd figure I'd try here before I try to pry this info out of an authorized service center who I'm afraid will try to get me to bring it in.
Anyway, I used an A/C voltmeter and measures about 32v AC across the terminals but INCLUDING the resistor. Will that affect the voltage reading? All I remember from 8th grade electronics class or Physics is Ohm's law V=IR
The resistor, at first looked to me to be
brown green black red but then I found that tolerances are only gold or silver which probably means the brown I'm seeing is probably gold. That makes it a 2,000,000ohm resister if it is Red Black Green Gold, does that sound reasonable? or am I missing a bar or something? I'm told to look for the gold/silver tolerance bar and read from the other end. The one side of the resistor is covered with some shielding but it doesn't look to be covering another bar though..
any ideas of the voltage, I can probably guestimate the watts needed by replacing the bulb (not in a socket) and seeing if the LCD is readable...
Jay
Jay
