Resilient channel and in-ceiling speakers?
Discussion in 'Home Theater Projects' started by dan_dj, Jan 16, 2004.
  1. dan_dj
    dan_dj Auditioning
    Nov 18, 2003
    14
    Would the use of resilient channels in the ceiling negatively affect the sound quality of in-ceiling speakers mounted in the same ceiling?
  2. Erik Farstad
    Erik Farstad Supporting Actor
    Jan 28, 2001
    560
    Dan, no it just decouples the ceiling from the joists above. But I always build "boxes" behind the in-ceiling speaker to help with the lower frequencies, just a thought.
  3. dan_dj
    dan_dj Auditioning
    Nov 18, 2003
    14
    Thanks Erik. Paradigm recommends placing 'loose' insulation behind and on either side of the speaker. How do you build 'boxes' for the speaker and what material?
  4. Erik Farstad
    Jan 28, 2001
    560
    Dan, just frame inbetween the joists so that you have about a 12x12" box and sheet with plywood...then fill that with a bit of insulation as well and you'll be solid! [​IMG] Make sense?
  5. dan_dj
    dan_dj Auditioning
    Nov 18, 2003
    14
    So you don't worry about sealing the box then? Since the sheetrock is decoupled from the joists and the speakers are mounted to the sheetrock then sealing the box would work against the resilient channel.
  6. Erik Farstad
    Jan 28, 2001
    560
    You can seal the box if you want to...just depends. I just ran in-ceiling speakers for all-house audio..and was not too concerned with fidelity, but if these are your main speakers for listening enjoyment...then I'd probably seal the boxes as well, for that would also improve on performance.
    But I doubt that will hinder the R-channel performanc.
  7. Blaine P
    Blaine P Agent
    Feb 11, 2004
    33
    Have any of you guys ran into your ceiling speakers creating too much sound in the upstairs rooms?
  8. Erik Farstad
    Jan 28, 2001
    560
    Nope!
