Resident Evil 0 Help Chess Part
Discussion in 'Archived Threads 2001-2004' started by Michael Pakula, Jan 7, 2003.
  1. Michael Pakula
    Michael Pakula Second Unit
    Jun 20, 1999
    393
    Im having some problems with the chess puzzle.
    Where abouts do I have to move the chess piece?
    -Mike
  2. JasonK
    JasonK Supporting Actor
    May 10, 2000
    676
    Michael:
    If you look on the desk in the same room, you'll see a chess board. On it are the exact same pieces. You have to make the big board on the floor look the same as the board on the desk.
    Only one piece needs to be moved, and it has to be moved to the right side of the chessboard, behind the piece in the upper right hand corner. (These directions assume you are FACING THE DESK.) If you move the wrong piece, you'll be gassed - but there's blue herb in the next room to cure you.
    Hope that helps somewhat. I'm at work, so that's the best I can do. Check Gamefaqs if you need a more detailed explanation.
  3. Michael Pakula
    Jun 20, 1999
    393
    Thanks Jason for the tips. I completed the puzzle.
    -Mike
  4. JasonK
    May 10, 2000
    676
    No problem. I just got to the 2nd disc, it's a fun game.
