Richard_M
- Feb 8, 2001
Would one of you kind experts let me know what I could expect as an output low freq range & spl from this Driver & amp.
It is mounted in 160L reflex enclosure.
It has a Redgum RGSW2 HL amp built in.
These are some of the specs
Thick aluminium sand cast frame
Straight profile Polyglass cone, foam surround
Edgewound flat copper wire 77 mm voice coil, black aluminium former
Efficiency : 93.9 dB
Nominal Power 225w
Program power 300w
Sensitivity 93.9
Cone Polyglass
Surround Foam
Fs 23.7
Vas 380.5
Qts 0.29
Qes 0.32
Qms 2.65
I realise this is probably a tall question, but just a rough idea would be great.
Richard
Nominal Power 225w
Program power 300w
Sensitivity 93.9
Cone Polyglass
Surround Foam
Fs 23.7
Vas 380.5
Qts 0.29
Qes 0.32
Qms 2.65
Richard
