Replay TV with AV Receiver & Dish
Discussion in 'Archived Threads 2001-2004' started by Don_K, Dec 25, 2002.
  1. Don_K
    Don_K Agent
    Jun 15, 2002
    27
    Santa gave me a Replay 5040, and my mind is slightly boggled. Would I want to connect it inline ... DBS to Replay to DBS-in on receiver? Connect it as a VCR? Do I really need to glue that funky IR-Blaster to the front of my Dish receiver?
    TIA
    Don
  2. Parker Clack
    Jun 30, 1997
    12,220
    75
    9,110
    Kansas City, MO
    Parker
    Don:
    You will need to have the IR-Blaster attached to your Dish to be able to get it to change your channel on your Dish to the correct one to record.
    You should have a manual that outlines the best way to set your unit. I am not sure of the outputs you have off you DBS. How do you normally set up your DBS to your receiver?
    Parker
  3. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
    Don, if your TV has enough inputs, I think the typical scenario is to hook DBS to Replay, and Replay to the TV. That way you can watch Replay, with sound, without needing to turn on the receiver if you're just watching the news or something. The receiver can get the sound from the TV, or from the digital audio output of the Replay.
  4. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
