Matt D K
- Dec 17, 2002
I'l looking at purchasing one of these units, Either one better than the other? They look pretty similiar to me....
Guess that is it. I'm leaning towards ReplayTV because it is broadband, and has component out and supports progressive playback. Is there anything I'm missing?If you must buy now, ReplayTV is your best choice in my opinion. If you can wait, TiVo has announced an HDTV model will be available, I believe later this year or early next year.
Chris
I'm leaning towards ReplayTV because it is broadband, and has component out and supports progressive playbackUnfortunately, the progressive out only works for the menu system and the picture viewer at this time, not for programming, but when I asked Sonic Blue about it, they said they would have an upgrade available later in the year.
I went with Replay simply because it was less expensive, but both work fine, IMO.
DJ
Hmmmm, that may be the best option yet. I told myself that this would be the year that I go to HD programming. I don't want to invest in D-VHS. A TiVo or ReplayTV that is capable of recording HD would be awesome. Since it sounds like they may be coming I guess I will just wait and see what gets announced this fall.
Thanks for the advice.
