replay loses customer (me), tivo gets one (1 Viewer)
george kaplan
I've had a replay tv since back in 2000, and have been very happy. But now I'm pissed. The modem has gone on the fritz, and it can't connect to their server. It last did so on the 4th, and I noticed this because my programming guide wasn't going past Monday. I've tried everything, resetting the machine, changing the phone number, forcing it to connect. No luck. I called customer service. They had me change modem speed, and all kinds of other things. No luck. But, before they will admit it's the modem and replace it, I have to try a complete reformatting of the hard drive. And lose 60 hours worth of programming. Nearly 30 movies I've recorded off of TCM. Either that, or lose the ability to record anything after Monday. Well, pardon my french, but fuck that. I guess that's their perogative, and they're not losing any money from me at this point, but I probably would have upgraded to a better replay machine at some point, but now, I'm off to the competition.
So now I have to figure out what tivo to get. I have direct tv, and want to minimize hassles. I guess I'll have to start researching it, though I don't have much time. I really need this up and running by tomorrow. DAMN replay all to hell. :angry: :angry: :angry: :angry: :angry:
Robert_J
Mississippi
The Hughes HDVR2 or one of its clones (Philips DSR7000) is what you need. The Philips is new but if they are like the first generation DirecTivos, they were built on the same assembly line using the same parts. There are many advantages over the stand alone models including the ability to record Dolby Digital (when available) and recordings are identical to live viewing. The only drawback is it will only record DirecTV signals. If you get your locals over the air or cable then the stand alone models are better for you but looking at the D* web site, it shouldn't be a problem for you.
-Robert
MikeSh
As far as I'm concerned, the HDVR2 is the way to go if you have or want DirecTv. I bought 1 and in 10 days had convinced the wife for a 2nd one w/o any hassle. A major feat. She really likes it too.
BTW, I have actually been to South Haven Ms and like it. I get there about once a yr when working in Memphis. We have a big site just across StateLine before the airport.
MikeS.
george kaplan
Well even though I have direct tv, I ended up with a standalone TIVO, because I just couldn't live with only 35 hours of space. My replay had 60, and the new tivo has 80, and there's no way I could go down to 35.
Chris Gerhard
Chris Gerhard
It is very easy to add additional space to a DirecTV DVR Powered by TiVo. I have a couple that I have added 120GB drives to and have over 140 hours on each. As far as your ReplayTV, you could format a different hard drive and try to do a net connect with a different hard drive. I always have multiple hard drives sitting around but it may not be that everyone does. I use a Showstopper for local channels and it does sometimes have problems connecting. Lowering the speed and selecting a different number sometimes fixes it for unknown reasons.
You might want to reconsider the decision to use a standalone TiVo with DirecTV. The DirecTV TiVo combo receivers such as the Hughes HDVR2 are so much better. Better picture quality, dual tuners, Dolby Digital audio and cheaper price and cheaper service fees. For only a little more than what you paid for your series 2 standalone, you could have an HDVR2 with 145 hours of capacity at best quality which is all the HDVR2 records. There is no comparison between the two for use with DirecTV. If you can return the series 2, you really should check out the differences before the return period expires. A standalone is great for OTA and basic analog cable but not for DirecTV.
Chris
george kaplan
Well I'm about as unhandy as they come. I've never done any of these hard drive upgrades on any of the replays I've owned (I just bought a bigger replay), and I'd have to be really convinced that I wasn't going to screw it up, since I'd be voiding the warranty. Any links to how this is done that would inspire that kind of confidence in me?
Stephen Tu
I also strongly urge you to reconsider ... remember for the standalone Tivo and Replay those hours are at lowest quality; at higher qualities it drops to half or two-thirds less space. The DirecTivo is "perfect quality" only; ~30 hrs or so on average (depends on what shows you record, since DirecTV compresses some more than others). Dual tuners is the killer advantage. Unless DirecTV doesn't offer locals via sat in your area, going standalone makes zero sense IMO for a DirecTV customer.
If you want more space than that, and aren't confident enough to upgrade on your own, there are various commercial sites that will do it for you (of course more expensive this way), that will warrantee their work. Some also offer pre-upgraded DirecTivos. Try www.weaknees.com for example.
Upgrading yourself is quite easy though, especially with the upgrade kits these places sell. Not much involved other than popping the case, screwing in a bracket, plugging in a new drive ...
george kaplan
Keep talking. You've got me thinking.
While I still have very, very grave doubts about my ability to do a hard drive upgrade, I'm contemplating this. But, let me ask this.
I currently have DirectTV. Can I just buy this new tivo and hook it up. Or do I need to modify my directtv service, and, God forbid, possibly have to get a new dish, or a new box?
Stephen Tu
Basically yes. The main thing you probably need to do is run another coax line in from the dish or multiswitch for the 2nd tuner. New equipment for the dual tuner capability is required only if you have an old, single LNB output dish. DirecTV would have to be informed you are using new receiver/access card, and that you are retiring your old one (if keeping old one for another TV have to pay $5/month extra receiver charge).
You can also just run one tuner at first if you don't want to get the second one up right away.
Bob Jackson
If you are an existing DTV customer you can get quite a deal on the HDVR2 with installation and upgrades to existing switches and stuff if needed.
See http://www.tivocommunity.com/tivo-vb...hreadid=113026 for a $159 offer + $25 shipping.
Just in case anybody wants one.
DIRECTV DVR with TiVo for $159, plus $24.95 shipping and handling. The dual tuner installation is included.
FOR EXISTING DIRECTV CUSTOMERS ONLY
New DVR Friends and Family Offer
Do you know any DIRECTV customers who are interested in the new DIRECTV DVR with TiVo? Then take advantage of the newest Friends and Family offer.
Applicable to existing DIRECTV customers only, the offer provides a DIRECTV DVR with TiVo for $159, plus $24.95 shipping and handling. The dual tuner installation is included.
Three thousand new DIRECTV DVR with TiVo units have been allocated for this test program, which is only available online through purchases made at the DIRECTV.com Web site. This offer will expire June 30, 2003, or when all 3,000 units have been sold. Remember, this program is valid for existing DIRECTV customers only.
All orders need to be placed at http://www.directv.com using the special DVR Friends and Family offer code "FFDVR."
DVR Friends and Family offer code "FFDVR." DVR Friends and Family offer code "FFDVR."
They also had $179 and $199 offers too.
Jay Heyl
I upgraded my ReplayTV late last year. I was shocked at how simple it was. And I even added a second drive, needing to create my own mount for the thing. There were a couple web sites that had complete instructions, even including pictures. If you're just going to replace the existing drive with a bigger one the upgrade is really easy.
Open up the ReplayTV box and remove the existing drive. (Undo maybe ten screws and pull a couple cables and you're there.) Attach this drive and the new drive to the IDE controller in your PC. Fire up the ReplayTV disk duplication software. Follow the simple instructions. Put the new drive back where the old one was in the ReplayTV box. Boot up the ReplayTV a couple times (maybe only once if you're lucky) and you're in business. Seriously, if I'd been doing just the one drive if would have been less than an hour start to finish.
Adding a second drive was a bit more difficult because I had to fabricate a mount for the drive (this involved actually using a drill to put two holes in a mounting bracket!) and I ended up having to make a trip to Fry's because the power Y adaptors I'd bought were the wrong gender. I also added a cooling fan that took a bit more fabrication and some experimentation. But I now have a 240-hour ReplayTV!
Vickie_M
George, how'd it work out for you?
We have 2 DirecTivos, and Chris upgraded both of them. He's a techy and I'm not, but I think I could have done it with those instructions above.
I'll never give up my DirecTivo...being able to record two things at the same time is heaven to me. It's come in handy for the Olympics, for the Academy Awards, for the 9/11 specials, and so many other things. I'd never want to go back to a standalone and just one channel.
george kaplan
Well I did get a DirectTivo, but there's been no upgrading. I'm just not confident enough I could do it, and I couldn't live without it long enough to send it out to have someone else do it. If I run out of space, I'll run out of space :frowning: , although no doubt I'll buy a bigger one when and if such a beast comes out.
Vickie_M
Do you have a webcam? I'd bet lots of people here would be willing to talk you through an upgrade over the phone, and if you had a webcam they could see what you're doing.
Dmitry
George, if you drop by the TiVo Community forums, you may be able to find somebody nearby who's willing to help you out. My recollection is that it didn't take me more than a couple of hours to upgrade mine.
george kaplan
Dmitry,
Thanks for the link, but I've been there (I check in every day actually), and I keep seeing "I tried to upgrade and I've ruined my Tivo" threads, which has only scared me more. :) I'm still thinking about it though.
Dmitry
George, what I meant was find some kind-hearted person nearby who'll be willing to do it for you, thus eliminating the need for it to be sent somewhere. I remember when I bought mine a couple of years ago I was also looking for info on how to do it and there was some guy who wanted his upgraded and wasn't willing to send it nor was technically inclined to do it himself. I think he found somebody in his immediate geographical area who just dropped by and did it for him.
george kaplan
Dmitry,
I understood what you meant, and in one sense it's a good idea. But in another way, I'd be even more reluctant to do that. What if some kind stranger came into your house and broke your Tivo? You'd be understandably upset at that person, but you really couldn't blame them, etc. If I did have someone else do it, I think I'd have to bite the bullet and go the professional route so there'd be some sort of guarantee. Assuming of course that there is a guarantee. I certainly wouldn't send it out if it came back broken and they just said, "Sorry".
Dmitry
George, I'm sure that you'll enjoy the TiVo regardless and I won't be pestering you with other ways to enlarge it's capacity any more :) You definitely make a valid point and if you're not comfortable with whatever approach, you shouldn't do it.
S205449
