HiHoStevo
- Oct 12, 1999
- Steve
I am trying to connect a Replay 3030c unit I just purchased to my DishNetwork 6000 receiver......
All of the connections are fine and I have updated the 2.3 software to 3.0. However I cannot find a code for the IR Blaster that will work my Dish 6000 receiver! I fear the only way to get this working is in the "fine-tuning" menu, but I am not excited about playing in there without some guidance.
I have also tried two different IR Blasters in case one was bad, neither has been able to control my 6000. With DishNetwork receivers you have to use the IR Blaster for control. The serial connection only functions with DTV receivers.
Has anyone else tried this combination? If so can you provide some HELP, pretty please!
Steve
Steve
