- Jul 19, 2002
I just bought some Titans and Atoms off eBay. They're brand new sealed in the box, but they're version 1. I was wondering if, when they get here, it would be fairly easy to replace the spring clips with binding posts from parts express? Or is the crossover network attached to the spring clip terminal cup? I'm comfortable enough w/ soldering and even w/ cutting a bigger hole for the binding post terminal cup and mounting it, but if the crossover is attached to the spring clip terminal cup, i probably wouldn't do it.
