Replacing Paradigm CC-350 with In-wall behind acoustically transparent screen?
Discussion in 'Speakers & Subwoofers' started by David Grove, Nov 21, 2003.
  1. David Grove
    David Grove Stunt Coordinator
    Apr 6, 1999
    227
    Building a new HT room in a new home. From previous system, I have Monitor 7's, CC-350, ADP-350's and PW-2200.
    Due to space restrictions forcing an over (or under) screen location for CC-350, I'm wondering about replacing CC-350 with a Paradigm In-wall (which one?). Would then use an acoustically transparent screen (pretty close to the In-wall). The Monitor 7's would remain on either side of the screen (i.e., not behind it).
    So, there are several issues-- timbre matching the Monitor 7's with the In-wall, and the In-wall located behind the screen while the Monitor 7's are in front of it. If I did this, I would use a Stewart Microperf.
    I can't try this as an experiment (without buying both screen and speaker), and wouldn't expect to find any comparable setup at any Paradigm dealer (nearest one is 2 1/2 hours by air, anyway).
    Any informed guesses or speculation on:
    1) What Paradigm In-wall would be appropriate?
    2) Would In-wall behind screen and Monitor 7's beside it hurt a seamless blend between Mains and Center?
    Maybe I should just go back to plan A, and mount CC-350 in soffit.
    Thanks for any comments.
    DG
  2. Heath_E
    Heath_E Stunt Coordinator
    Mar 27, 2001
    157
    What projector are you going to be using? If it is an LCD, I wouldn't use a perforated screen due to bad interaction with screendoor effect. Actually, if I were you, I would just get a regular screen and mount the CC-350 below it, aiming it up to ear level.
  3. David Grove
    Apr 6, 1999
    227
    Using a DLP (NEC LT-150).
    Yeah, I'm thinking I should just forget about trying to locate center behind the screen.
    DG
