Replacing old Subwoofer
Discussion in 'Archived Threads 2001-2004' started by Eric Wood, Dec 6, 2001.
  1. Eric Wood
    Eric Wood Stunt Coordinator
    Oct 4, 2001
    54
    I have a Mirage MS-12 subwoofer now. But, I feel that it is not adequate to my wants(needs). So I was thinking of getting the Shiva driver and putting it into the cabinet after excising the old mirage subwoofer.
    The spechs on the MS-12 are as follows
    Amp type----High current Discrete Mosfet – 100 watts -400 watts peak .04% THD
    Freq. response---- 28hz-150hz +0/-3db
    A/V contour----------Audio[​IMG]lat – Video:[email protected][email protected]
    Phase switch --------N/A
    Variable low pass----50hz-150hz 18db/Octave
    High level high--------Approx. 85 hz
    Outputs-----------------high level
    Dimensions
    H x W x D in-----16.25 x 17.25 x 15.06
    cm----41.3 x 43.8 x 38.25
    Is this feasible, logical and would it be a vast improvement?
    I want to leave the Amp in!
    Eric
  2. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Yes, no, depends on what your definition of 'vast improvement' is. For me, no way, as you're trading one boom box for a boomier one with a higher F3. It will probably play louder though.
    As always though, YMMV.
    GM
  3. Eric Wood
    Oct 4, 2001
    54
    I think I got my answer!
    Eric,
    Thanks for the inquiry! In most cases (99 out of 100) dropping a new driver into an existing commercial subwoofer doesn't really work well at all. Typically, the box and amplifier are tuned to a specific driver. There's custom EQ/limiting circuitry used in most commercial subwoofers, that are matched to the original driver. Replacing this driver with a different unit will often result in worse sound quality.
    Rather than rebuild the sub, I'd recommend selling the unit, and using the funds to build a full-on DIY unit. Building your own subwoofer is pretty simple (provided you can cut wood, or know someone who can), and the results can greatly exceed commercial offerings, on a dollar-for-dollar basis. A single Shiva, our AVA250 power amp, and your own cabinet (use one of the reference designs at http://www.adireaudio.com/Tech%20Papers/shiva_apps.htm) can result in VERY high levels of performance, for under $400.
    Alternatively, for $399, our Rava (http://www.adireaudio.com/rpd/rava.htm) will exceed the capabilities of your MS-12, and is a fully-assembled sub; no construction required.
    Thanks again,
    Dan
    Adire Audio
