What accessories do I need for this upgrade such as charging gear, phone case and etc?
Also, how difficult to transfer data from old phone to new one?
Nope, however, I did go down to my local AT&T store at 4:30 p.m. and purchase the iPhone 13 Pro Max. I'm home now and everything is set up except facial recognition so I'm good.Wait. Thought you already did this a while back, no?
It’s a charger. It charges. Plug in wall and forget about it.
I have no idea if it runs hot. But my house hasn’t burnt down yet.Well, given the handful complaints on Amazon and not sure if many just do as you suggest and never notice them possibly running much too (potentially dangerously) hot, prone to failure, etc... as those are probably the most likely issues w/ this sort of gadget...
IF this charger typically runs extremely hot (probably due largely to its small/compact design), I'd probably wanna take a pass on it...
_Man_
While I don’t own a 13, I suspect you should get a chin strap to keep your chin from hitting floor whenever you look at the screen or it’s performance astounds you in some other way.What accessories do I need for this upgrade such as charging gear, phone case and etc?
