Replacement woofer
Discussion in 'Home Theater Projects' started by Gene Severn, Oct 19, 2003.
  1. Gene Severn
    Gene Severn Stunt Coordinator
    Jun 14, 1999
    77
    Could anyone recommend a less costly replacement woofer for the Infinity Reference 2000.5??? The suggested replacement thru Infinity is $129.00. I am a little short on cash at this time so I cannot affort to replace all 5 speakers. Thanks in advance.
  2. Jake K
    Jake K Stunt Coordinator
    May 22, 2003
    132
    Maybe if you ask them nicely they will give you the t/s parameters for the drivers and then you could find a suitable replacement. But it probably won't be as good as the original. What happened to the woofers anyway?
  3. Gene Severn
    Jun 14, 1999
    77
    It just died...quietly without warning.
