Replacement for VSA-AX10I, VSX59TXI with more power>
Discussion in 'AV Receivers' started by RobD, Oct 15, 2003.
  1. RobD
    RobD Second Unit
    Jan 21, 2003
    264
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I beleive the AX10Ai IS the 59TXi and the 868AVi IS the 59Ai, just the European models. The power rating may have thrown you since the AX10Ai was rated for 200W @ 6ohm, not 8ohm which the 59TXi is rated at. The specs for the 868AVi and the 59Ai are exactly the same.
  3. RobD
    RobD Second Unit
    Jan 21, 2003
    264
    I thought the 59TXI was using the same amps as the 49TXI? The AX10I is rated at 160W RMS into 6Ohm whilst the spec seems to be 200W RMS into 6 ohm for the AI.
