'Repeat All' Option on Home made DVD's?
Discussion in 'Archived Threads 2001-2004' started by DeathStar1, Dec 15, 2002.
  1. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    Hey all,
    I just found out that Ulead, while a good program, has a nasty little side effect. It'll just play one chapter, and then go back to the main menu. There's no play all repeat option, and there's no way to let it just run through the DVD all at once.
    Either that, or it's just my creative labs DVD player that has no play all option for DVD's. Anyone recomend a program that does?
  2. David*Ryu
    David*Ryu Auditioning
    Dec 12, 2002
    13
    I use DVDit, and it allows you to link chapters by selecting what chapter should come next. I assume that is what you are trying to do. Theoretically, you should be able to link the last chapter to the first for an infinite loop if you wanted as well. It isn't the best out there, but it is simple to use. You may want to check out www.doom9.org. Although they spend a lot of time talking about copying dvds, I have learned a lot about transferring DV to dvd from there.
